Hi,
Filled the pool a week ago and put 5 lbs of Stabilizer into 2 socks starting on 5/26 (as recommended by the Forum). 99% of the stabilizer powder has dissolved but CYA is still very low. Test results as of last night. The CYA number is an estimate since the last number on the measuring tube is 20.
FC = 0.5 (added 45 oz of bleach per the app)
CC = 0
pH = 8.0 (added 38 oz acid per the app 30 min after the bleach)
TA = 120
CH = 200
CYA = 10 (or less)
Should I put another 5 lbs of Stabilizer in the socks?
I'm new to adding Stabilizer...this is my first drain and refill. I didn't expect the CYA to be this low after already adding 5 lbs. Chlorine is burning off fast. I've already used a gallon of bleach since last Saturday.
Strop
CC = 0
TA = 120
CH = 200
CYA = 10 (or less)
Strop
