- Sep 29, 2012
- 121
- Plaster
- Hayward Aqua Rite (T-15)
Hello
I have a new pool and today we had our “new pool” orientation with the tech who works with the pool builder. I have spent a lot of time reading about adding CYA using the sock method on the forums here at TFP. I asked the tech how they add CYA to a pool like mine and he informed me that they simply add undissolved CYA granules to the skimmer. I AM NOT DOING THAT!
After explaining the sock method to him, he stated that I should take the basket OUT of the skimmer and place the sock/CYA in the skimmer directly (without the basket). Furthermore, he stated that in addition to the CYA/Sock, I should place another sock (empty) into the hole in the skimmer closest to the pool in effect plugging this hole. This is the part I do not understand. I have attached a pic showing my skimmer and the holes at the bottom. My understanding is that the hole closed to the house goes directly to the pump. However, I am not sure what the other hole (closet to the pool) does. I thought it takes water from the main drain and dumps it into the skimmer, but I could be wrong.
I guess my question is why would I in plug up the hole closed to the pool in order to facilitate adding chemicals into the skimmer? Am I correct in assuming I can simply put the sock/CYA into the skimmer basket and be done with it not worrying about the holes at the base of the skimmer? Also, when using the sock method, do you have to go to the return valves at the pump and turn off the valve for the main drain return in order to facilitate/enhance suction at the skimmer? TIA
