I’m having a small algae problem. I tested my water with an FAS-DPD kit. CYA was 100. For grins I tested again with a Clorox test strip, and it seems to have confirmed that reading. (See attached). However, the test strip says I am within desired range.
And CYA is the same as stabilizer, isn’t that correct?
Pool math says I need 3 gallons of liquid chlorine. Will that remove the slight green algae stains?
Thanks!
Thanks!
