Hi All...new guy here, thanks in advance for the patience! I'm pretty sure I know the answers, but would still like opinions. First, here are the numbers (waiting on the Taylor K2006 test kit, should be here Monday).
FC: 2.46
TC: 2.54
CC: .08
pH: 7.5
TA: 75 (I have since added sodium bicarb to bring this up)
Calcium Hardness: 314
CYA: 130 (NEED TO CONFIRM)
Phosphates: 0
I have brushed, vacuumed and cleaned the filters. Pool looks clean, but water is cloudy. Obviously, I have a CYA issue which is going to require higher levels of chlorine. I have stopped the tabs and am using granulated shock now, since I don't want to run the CYA up any further. Pump is running extended hours to help out.
My main question is this: am I wasting time trying to keep it going with that high of CYA? Was hoping to limp it through the summer and drain/refill when water is cheaper in the fall. Part of me doesn't think it's worth it and just need to pull the bandaid off. Or am I close to having clear water?
Going to switch to non-stabilized tabs going forward to avoid in the future.
PS-I am in the CenTex/Austin area. Hot and full sun on the pool. I'll edit my signature to reflect that!
Thanks for the help!
FC: 2.46
TC: 2.54
CC: .08
pH: 7.5
Phosphates: 0
