hi all, new here, first post and looking for advice. I’ll try to make this short, mistakes were made. So I opened my above ground pool to clear water. Tested with a strip ph and alk were spot on fc was zero. I used a whole bottle of Clorox Xtra Blue shock. No change to FC. bought liquid chlorine, put a lot of that. No change to FC. have read about “chlorine lock” and CYA problems online so I decided it was time for a real test kit. Got the k-2006. Tested CYA it was over 100 by a long shot ( test only goes up to 100) decided I needed to drain and refill. My above ground is dropped about 2 feet Into the ground so I only emptied it to the dirt line worried about a collapse. Refilled way up. CYA now reads around 70. From what I read this is still too high. I added 15oz of 10% liquid chlorine anyways tried to make it work . FC reading now .6 (point 6) and CC is reading 2.6?! Alk and PH are spot on. I have a 10 by 16 oval about 45 inches deep . Calculators tell me I’m around 3750 to 4000 gallons. If you are still reading this thank you. HeLP?!
