Pool was well balanced last I tested. Cya was at 90 and a SWG was installed. I am hoping the CYA continues to drop so that I can run lower free chlorine and still sanitize the pool. I’m not sure at what rate the CYA is going to drop, but since I’ve been running chlorine tablets for so long, I do not own any conditioner. Once the CYA drops to a level that I want to maintain do I just put pucks in floaters to supplement the saltwater generator or do I actually add CYA conditioner using the sock method I’ve read about? If I need to add conditioner for A pull my size. How much should I have on hand?
I’ve run high free chlorine to compensate for my high CYA levels basically since I found this place very successfully. What would you consider the optimal CYA level for saltwater generator pool knowing that I’m offsite Monday through Friday.
