Closed without incident last year. CYA was 70. (I have a SWG) I pumped out about 18" of water and put on my new mesh safety cover. I opened this weekend to a relatively clean pool. We've had a lot of rain and snow the past month and the water was just about up at a proper level. I spent the weekend dialing in the chemicals. The weird part is my CYA, which I expected to be pretty low after the winter, was 60. I measured twice on each of two room temperature samples with fresh reagent. Does this seem normal? The water isn't perfectly clear, but I can easily see the drain at the deep end. I can't imagine that would affect a CYA test, though.
