Caco
0
I think you may be focusing on the wrong thing to try and save costs. Yes lower your pump runtime more. Try dropping it by an hour, wait a few days drop another hour etc etc. You will see when your water doesnt look filtered enough and then bump it up one more hour. Personally I run mine for two hours a day in the evening as thats when I test and add chems. I tried for 3 hours and noticed no difference so felt comfortable with that. This should save some money on your power bill
Also next spring when you go to open look around for good prices on chlorine. This is the best way to save on chlorine. If you find a good sale you can stock up too, just make sure you keep it out of the sun in a cooler area and it will keep fine. You dont want to skimp on the chlorine and run the risk of an algae outbreak, which then would require a slam or not be keeping the water sanitary. There is usually a post that start up at the beginning of the season with people posting good prices, so keep an eye out for that
Yes you will need to keep an eye on your ph and TA next year. For now I would just keep it in swimmable range and think about looking at it in the spring. High TA wont cause any issues apart from helping you ph to rise quickly. Its something to tweak when the rest of your pool is fine
I hope you get plenty of swim days in before you have to close. I will be opening in two months and I cant wait!!
