- Mar 11, 2023
- 29
- Fiberglass
- Pentair Intellichlor IC-20
I purchased Haviland Salt Support so I could start adding borates to my pool. Salt Support says to never use it in a pool with CYA above 50, but TF says for a SWG pool I should have my CYA at 70. I want to use borates to slow my PH rise, but also struggle with maintaining adequate FC levels on the weekends, probably due to UV exposure. I’m sure I’ll eventually figure out what to put the SWG on for sunny weekends to maintain, but I haven’t as of yet. Anyone have a scientific reason why they might recommend CYA needs to be lower with Salt Support, or do you think they’re just following the typical 30-50 PPM CYA recommendation?
