Hello & happy pool season!
Last year, I ran into major algae problems because my CYA was way too high from using pool store shock. After draining about half of the pool water for the winter, and replacing it with fresh hose water, I was optimistic that maybe my CYA levels would be just where I want them this year. No such luck - I just tested and the CYA is too low to register on my K-2006 kit. I am wondering if anyone has any advice for how I should go about raising the CYA, as I'm not sure how much is in there currently.
From my research on this site, it sounds like I need to go buy some solid CYA, dissolve it slowly, and retest CYA level in a week or so. The problem is I need to start a SLAM on my pool, and I'm not sure how to go about it without having a concrete number for how much CYA is present.
Which brings me to my next question. I still have several 1 lb packages of pool shock granules - should I add these to get some chlorine & stabilizer in the pool? I know traditional shock is normally not recommended - I'm just wondering if I can get rid of this stuff and maybe start addressing my CYA problem? Right now my FC is zero, so I really need to get some chlorine in there. Would I be better off just putting in some bleach?
So sorry for any silly questions - I started with TFP toward the end of last year and I have a lot to learn! Any help would be greatly appreciated!
