- Sep 23, 2015
- 1,630
- Plaster
- Astral Viron V25
Hi all, I spent the last three weeks reading up and devouring as much information as I can about the care of my 14,400 gallon salt water pool, from blogs, YouTube channels, a few books, and then also going back and forth with my own Taylor test kit as well as getting readings from Leslie's pools. With the help of Leslie's I solved a pretty serious algae problem and since then I've been keeping the chemicals pretty well balanced.
There seems to be little controversy over the recommended ranges for most of my water measurements: pH, TA, CH, Free and Total Chlorine.
But what is baffling is the conflicting recommendations about CYA levels.
Orenda Tech and Pulsar Systems, which are concerned about chlorine effectiveness, seem to suggest sticking around the 20-30 ppm (maximum). Other places (Leslie's), websites, and apps (TFP PoolMath for example) seem to suggest CYA levels upwards of 50 ppm.
However, I'm concerned about chlorine effectiveness. Quick google searches on "CYA effects on disinfection" seem to suggest that you get the most bang for the buck (in terms of UV protection) at 10 ppm CYA and above that it's diminishing returns. However, at CYA levels above 20 ppm you lose a lot of chlorine effectiveness for disinfection. Bob Lowry and Orenda Tech suggest that you need chlorine levels to be at least 7.5% of CYA levels, so at 60 ppm CYA you'd already need more than 4.5 ppm free chlorine! Pulsar Systems suggests the same, except they state it by this 14:1 ratio (CYA Effects on Disinfection - Pulsar Systems)
So what am I to think? Right now it's winter and I'm keeping my CYA at 20 ppm, but given that it's hard to lower CYA levels I am scared to go higher and have algae issues down the road. All the research I've done suggested that I'm near the sweet spot, but am I sure? Heck no.
Thoughts?
Geday Chris and welcome to the forum.
One very important point to note is that the vast majority of information and/or advice within the pool industry is based on what best suits commercial applications. The industry has always found it difficult to impossible to separate commercial pools from the back yard residential pools. They find it very difficult think outside the box even just a little bit.
Over the years I’ve read through lots of articles like the Pulsar one, I stopped reading the Pulsar article when I got to “remediation of diarrheal fecal accident” part which is something that not often discussed when talking about our residential pools. My point here is really that that article is for the management of commercial pool.
The industry is quite rigid with the 1-3ppm FC limit and maintain pH at 7.4-7.6 to maximise hypochlorous acid, the active part of pool chlorine. We’ve known for ages that hypochlorous acid reacts with cyanuric acid to form chlorinated cyanurates but unfortunately the industry in general does not apply this to the benefit of residential pools. The 7.5% ratio is well known but the industry always starts from a maximum 3ppm FC and works backwards to get an ideal CYA level. It never seams to ocure to them to start from a known CYA level and apply the 7.5% to get an ideal FC level.
To that end the FC/CYA Levels is the easiest way to set FC targets.
I use the Taylor CYA comparator which starts at 30ppm so 30ppm would be my minimum but I maintain my CYA at 50ppm through winter and top it up to 70ppm through summer. We also recommend to round CYA up to the nearest 10ppm to find the ideal FC target.
