Good morning,
Has anyone ever experienced a dramatic decrease in CYA not attributable to adding fresh water, CYA removal kit use, or any other contributing factor? At this time last year, we experienced a dramatic drop in CYA over a few weeks. We were averaging upper 50's to 60 for the entire season until one point where it began to decrease and then dropped from 35 to 5 within a week. Of course, we were unable to maintain chlorine during this time and no one could explain how this could have happened. In fact, after daily trips to the pool store, I was eventually told I could not be telling the truth about the situation and they were done with helping me.
We opened the pool this year around 4/15/22 and had been running along quite well in spite of this until now. It is a 33,000 salt water pool with a heater and auto cover which we keep closed unless the pool is in use. Very little rainwater gets in the pool. Water analysis results below:
8/11/22
Salt 3950
pH 7.4
TA 78 (unusually low- usually 110's)
Ca 305
FC 5.9
TC 5.9
CYA 61
8/19/22
All results similar except FC and TC down to 0.1
Shocked and added stabilizer as our SWG recommends 60-80
8/26/22
pH 7.2
TA 148
Ca 283
FC and TC 0.2
CYA 19 (run twice)
8# of stabilizer, shock and pH plus added
8/27/22
pH 7
TA 139
Ca 304
FC 0.3
TC 2
CYA 46
Spoke to the Autopilot technician because we could not get a chlorine reading. He checked amps/volts and said we were making chlorine. He suggested manually testing the cell which we did. It bubbled immediately and we did a test strip which indicated chlorine being produced. He also suggested a super shock of getting the pool to 30ppm chlorine. I did that with 9 gals. liquid chlorine after getting the CYA up closer to the recommendation by the SWG mfr.
Test results the next morning indicated no chlorine in the water at all. I took a sample the next day and it was confirmed.
Salt 4050
pH 6.9
TA 130
Ca 308
FC 0.1
TC 0.3
CYA 89
We cannot get the chlorine level to normalize. I rechecked this morning after the SWG was on boost yesterday and still no chlorine showing. This is essentially the same scenario we had last year. I cannot believe it has happened again and there is no one who can give me an answer as to how it happened once let alone twice. I hope someone can help us.
8/11/22
Salt 3950
pH 7.4
Ca 305
FC 5.9
TC 5.9
CYA 61
8/19/22
8/26/22
pH 7.2
TA 148
Ca 283
FC and TC 0.2
CYA 19 (run twice)
8/27/22
pH 7
TA 139
Ca 304
FC 0.3
TC 2
CYA 46
Salt 4050
pH 6.9
TA 130
Ca 308
FC 0.1
TC 0.3
CYA 89
