Once a month I take a water sample to Leslie's to keep my pool warranty if effect. Today I noticed that the Leslie's test had my TA at 49 when I tested it at 70 just before going. They also tested my Ph at 7.9 when I tested at 7.6. I asked about the differences and he explained that there is a formula that must be used when CYA is above 50. TA - (CYA/3). I use the Pool Math app and entered my TA at 70 and CYA at 78 and there was no recommendation to add baking soda. Does the Pool Math app not take high CYA into consideration or utilize the formula? Should I be entering the TA result from my Taylor kit, or should I do the conversion before entering the number into the Pool Math app? I know that it would be better to get my CYA below 50, which I will work on, but I want to make sure my TA isn't too low. TIA.
