Cut liner to add second pump
Jun 28, 2017
11
Chardon
I have a 20ft x 48in summer waves elite. I cut the existong return hole to fit my sand filter with no problems. The existing hole has a double liner area. I wanted to add a second inlet and return to the pool, has anyone done this on the normal not double reinforced section of their pool?
I bet someone has...........try doing a search in the white box at the top of the page. It goes to only TFP threads so that should help narrow it down some.
I THINK (this is my gut talking) if you used gasket material or such of both side that will help reinforce the pool wall.
Kim:kim:
