There are lots of scattered experiences throughout this forum regarding current sensing relays to trigger the SWG's power source based on current flow to the pump. There is not a clear solution though - "buy this, hook it up like that".
This thread is an attempt to get a direct answer to the question: "I have a variable speed pump and want my SWG to turn on when my pump does."
(mixed motives here... I need a current sensing relay and want an answer for my setup, but also see a gap in information that this forum could benefit from so trying to make this more generic than my personal question).
Example Setup (shouldn't matter much):
Questions
Simpler is better, smaller is better. Don't want alternate sources of power, additional relays, etc.
I will buy what this thread converges on and report results with photos.
Thanks!
- Pentair 011018
- Circupool SJ-55
- 240v feed from basement sub-panel to junction box at pool pad
Questions
- What current sensing relay would work well? Where can it be bought?
- Where to mount the current sensing relay? In my case it needs to go either in my existing junction box (if small) or in a peripheral box. Some have sub-panels at the pad, and normally you don't mount things or splice in a panel. What's the right way to do this? Pictures?
Thanks!
