- Jul 14, 2017
- 817
- Plaster
- Hayward Aqua Rite (T-15)
The last couple of springtimes, Ive opened to a pool that has 1) a lot more scale buildup than what i closed with and 2) a lot of crystalline precipitate in the bottom of the pool. It fizzes with acid so assume its calcium (calcium carbonate??) 3) ph high well over 8.0.
This winter, Im hoping to keep the csi/ph a little more maintained if possible to hopefully open up without scale and a big precipitate mess. But thats hard to do when the ph to maintain balanced CSI is over 8.0 (8.2 with 40 degree water). The last thing I want to do is pour in a ton of acid over the winter and then when the water warms in the spring find out I way overshot and have an acidic pool.
Also its worth asking….is the poolmath csi equation valid at temps this low?
Im inclined to put enough acid in so the ph seems to be just a bit above 8 and hope for the best. I won’t be able to maintain this on a regular basis but am hoping to check it every few weeks until the springtime. Anybody think this will lead to trouble or is it just not worth doing?
