Here are my test numbers from this morning taken with my Taylor K-2006C and Taylor K-1766 kits:
FC 6.5
PH 8.0
TA 50
CH 230
CYA 40
Salt 3000
Temp 65 degrees
CSI -.31
I have a plaster pool and understand that I want to keep my CSI above -.6. MY CYA is low and once I bump my CYA up to the recommended level of 70 that change will drive my CSI down lower than it should be at -.65 if I maintain a target level PH of 7.8. Do I need to bring my TA up to 70 or so in order to keep CSI above -.6 and maintain recommended PH levels? Or, alternatively, should I keep my CYA as is for the cooler months and bump it up to 70 next summer? Any thoughts would be appreciated. Thank you.
FC 6.5
PH 8.0
TA 50
CH 230
CYA 40
Salt 3000
Temp 65 degrees
CSI -.31
