The pump union nut to my Jandy Stealth pump cracked. When the nut is off the pump is sitting a bit lower than the connector so maybe the equipment pad sunk a bit and that stress caused the nut to crack? I'm not sure. I tried two different split pump union nuts where it is two sides connected by screws, but neither is large enough for this application.
The way it is plumbed there are 4 valves that look like they would have to be cut out and all the plumbing replaced to fix this -- well beyond my abilities. Is there some other fix? Are there any recommended professionals in the Dallas area?
I've attached pictures. Sorry my pad is a little messy. You can see my attempt at duct taping the nut in the second (that didn't work).
Thanks for any ideas /information-
Jason
Jason
