I have cracked 4 manifolds on my FNS plus 36 DE filter. One on the top by the bleeder and 3 on the bottom where the seam is molded.
This has happened over the course of about 4 years each one spaced out about the same.
I have a 1.5hp pump and all 2” fittings. Each time it’s happened my pressure is running at the “clean” level.
Are these manifolds that fragile? Should I upsize my filter? Should I never allow the pressure to get that high? I also saw there is a heavy duty one on amazon.
Any input is welcome. I’m contemplating buying a FNS Plus 60 or purchasing the HD manifold.
