I will be leaving our home in Honduras for the summer and will cover the pool while away. Although we normally use a SWG, while we're gone I'm going to turn off the SWG and have our gardener keep it stocked with chlorine pellets in a floater.
I will run the pump for an hour or two each day to circulate everything and turn off the skimmer and just circulate through the 2 main drains. And I have an automatic water filler to keep it filled with enough water as it could be very hot and dry while gone.
Any other suggestions of things I should be doing?
Thanking you in advance!!
