- Apr 18, 2017
- 83
- Vinyl
- CircuPool RJ-60 Plus
Hello, we are buying a home that has a large inground pool (25 x 45). We live in Michigan and get significant snowfall during the winter. The current owner covers the pool in the winter with a standard cover held in place by the "water balloons" (sorry I don't know the technical name). However, that wont work for me because I have three dogs (one large St. Bernard that is 140 lbs and still growing) that will undoubtedly walk on the cover (our entire yard is fenced, not just the pool) and they would sink (I assume) so I will need to buy a cover to use over the winter that will support the weight of them since I can see no way to keep them off of it (if you have suggestions, I am all ears). I'm also concerned that in the winter, with snowfall, they may not recognize where the "pool area" is and may urinate and defecate on the pool cover so am thinking it may be best to have a solid material vs. a mesh material.
What are you guys using/doing if you have a situation similar to mine? Do you have any suggestions/recommendations for a type or style of cover?
Kindly,
Steph
Kindly,
Steph
