Brand: Cover Pools
Part #: 050239
I could use some help figuring out what happened to the shear pin hole within the pool cover shaft. This is my third season as a pool owner and the automatic pool cover has been the biggest challenge of managing the pool. The shear pin seems to always break. After watching our pool cover person knock it out and replace it 4-6 times the first couple seasons I've since learned how to do it myself. My current challenge is that the hole within the shaft doesn't seem to be lining up like it normally does. I'm unable to see the hole to knock it out with a screw driver. I've gently turned the shaft 360 but do not see it as the shaft turns Any thoughts, ideas or recommendations?
Some additional context. I've had the following maintenance on the unit over the first 2 years:
Part #: 050239
- Year 1:
- Replaced the rotting cover that wasn't being cleaned and maintained each year.
- Year 2 (last year):
- Had a new concrete pit and drains poured to ensure the motor and shaft was sitting level.
- Motor, shaft and pulley tune up. Everything was stripped, greased, serviced and put back together
