We have an Aquaguard Electric pool cover with polymer side track ropes to open and close. The mechanism operates with a hydraulic pump. There is only one company that services / repairs Aquaguard in the UK and they are based hundreds of miles away. The cost of getting them here is extortionate! The cover was installed in 2007 and was serviced three yers ago, with a new cover and mechanism installed. From my research ( there seems to be little info about Aquaguard on You Tube) I believe there is a way to adjust the speed of opening & closing the cover. At the moment, it closes to about 1 metre short of the pool end. Only by going back & forth about 6 times can I get it to fully close. It opens fine. I have checked the obvious things such as debris in the tracks, water in the pit, oil in the pump etc. All is good. From looking at other units, some seem to have a pressure release valve that once released, allows you to use a wrench or screwdriver to adjust the speed of the cover. I wonder if anyone could see from the attached photos whether that is an option on this system as I am not sure what I am looking for? In my naivety I thought there wold be two torque adjustment options on the mechanism, one for opening & one for closing. But I can't see any. Unfortunately we inherited the pool with the house and there is no manual and I can't fine any on the web. Any pointers gratefully received as I am trying to avoid having to pay £1500 for a site visit!
Thanks Dougal
Thanks Dougal
