my CYA is high, ~130, and my chlorine levels are low. used pucks for about a year now.
yesterday i drained half the pool and in the process now of adding water back in, and will add liquid chlorine.
1. i noticed a leaf stain at the bottom of the deeper end of the pool (1 day old) how do i get rid of this besides scrubbing as much as i can? it looks better but stain still there. is staining more prevalent with lack of chlorine? (image below)
2. how do i know how much liquid chlorine to add for a 12,000 gallon pool with low levels, and wanting to get it to normal levels?
3. help me understand something. these chlorine pucks are bad because they add chlorine and CYA into the pool. CYA necessary to prevent chlorine from being evaporated with sunlight, but when water evaporates and chlorine used up, the CYA stays in the pool. when you continue to do this, the CYA gets higher and higher, requiring a higher level of chlorine necessary to work in sanitation. do i have this right? but the "right way" i hear is to use liquid chlorine. if i do this, do i need to manually add CYA? when you do it this way, the CYA also stays in the pool and accumulates the same way right? eventually, will i have to drain the pool when the CYA gets too high like with my pucks?
