Hello to all,
So I drained my spa tper Marks instructions and drew down the water till about the lower 3rd of the spa light niche. I easily removed the light by unscrewing only the 12 o'clock screw.
I packed the ground and the main LED electrical romex w pool putty per instructions / while the water was down, I pulled both drains & they looked great, but I put some putty around the screw receptical areas.
In Vain work:
no matter what position, angle, how much I crammed in the electrical wiring, I could not get the light to seat fully in the niche so the gasket was flush against the spa pebble sheen. The top is flush where the screw is, but the bottom would just not fully go in all the way...I won't tell you how long I tried..,but the insanity clause was invoked.
Here's the tag that floated out of the niche. I'm all ears. Also posting a pic of the light again prior to deinstalling
Thank you in advance
Tstex
In Vain work:
Tstex
