Thanks Jim,Nick,
Really depends on what your water looks like..
Algae can clog a DE filter in hours...
A filter pressure of 40 is insane.. !!!!
The higher the pressure, the harder it is to push water through the filter..
It should be down around 10 in your case..
It is a little late to blame someone else...
Thanks ajw,Well it did. We don't know how much dust and dirt blows into your pool from the Texas plains.
What is your clean filter PSI?
Was there DE in the filter?
How much DE do you add after cleaning the grids?
Do you have an MPV or a slider valve?
When you say 'well it did' do you mean it is possible that a clean filter got that bad in a few weeks even though we have had no algae?
I put in 9lb DE and the psi has remained steady at 17.
Don't know what an MPV or slider valve are.
That is from trichlor tab use.After the Maintenance guys put in 3lb dichlor the cya got to ~200. I
Thanks James, what is the significance of the crushed ribs?You can see the ribs are crushed flat and the broken plastic goes into the outlet of the filter.
There was a recent thread with this exact issue.
Apparently the heater was disconnected some time ago and left so that water just flows in and out of the casing.
Nick,
You are supposed to take all the grids apart and clean them.. Then put them back together...
The first time I did that I almost cried...it took me an hour to finally get them back together... It now just takes a couple of minutes..
I gave up on DE filters a long time ago.. What a pain...
I now have a large cartridge filter and clean it once a year.
No algae.We don't know if you have algae.
Does your pool pass a Overnight Chlorine Loss Test?
What model and size is the filter? 9 lbs sounds high.
With a clean pressure of 17 you should backwash or clean the filter when the PSI rises by 25% to 30% or around 23 PSI.
You should not let the PSI get to 30 or 40.
MPV Valves - Further Reading
www.troublefreepool.com
Slide Valves - Further Reading
I believe you, he had put in new tabs in addition to the 3lb dichlor - which I assume is what kicked his reported cya up from 100 to ~200.Texas Pool Builders hate SWGs for some reason and love trichlor tab feeders.
Exclusive trichlor tab use is a disaster.
The grids are clogged with something, maybe mud, but hard to tell for sure.
