Hello all,
I am living in Costa Rica, and in the process of building a B&B in the jungle.
We have been working on the design for quite some time, and I am now looking at the pool schematics.
Most professionals around here are not interested in doing a proper analysis or studies. So we have taken it upon ourselves to make the best possible pool system for our area/climate.
I have browsed through this forum and other places on the internet for most info, and compiled it into the attached schematic (which I can't seem to upload any bigger).
![pool schematicKL.jpg pool schematicKL.jpg](https://www.troublefreepool.com/data/attachments/57/57824-8b9ce5ed6b397635822d30c58bffb840.jpg)
An important part of building in the jungle is maintenance, and trying to go back to 'simple' solutions. We like to steer clear of complicated electronics, or automated solutions. Not because we do not like them, but because things tend to break quickly here, and fixing them means ordering replacements from the States, that take weeks to arrive.
We are 2 km from the ocean, in the middle of the rain forest. We run most things on solar panels, but the grid connection supplies heavy users. This means this equipment gets treated to terribly 'noisy' electricity with lots of spikes.
POOL SETUP:
The main setup is a 20.000 gallon pool, with an infinity edge and a separate (heated) 2.000 gallon spa.
I calculated the total dynamic head loss at 30 ft, but a dry start also requires overcoming a 36 ft head, as the spa is located higher on the mountainside.
I have not found much information for exact TDH calculations, so am not sure if this is completely accurate. And theory and practice will be somewhat different supposedly.
We would like to run this on a 3/4hp pump like a HAYWARD Tristar SP3207EE or something similar. Most important is a pump that's simple. We have lost fancy pumps the terrible electricity here.
With a 2x daily turn over, we would need 28GPM of flow if running the pump 24hrs.
This pump could theoretically push about 100GPM at 30 ft head, but going down to a smaller pump, I can't overcome the additional head of the dry startup.
I prefer to keep the pump as small as possible, but can't find a solution that can overcome both problems.
Looking at the chart, I'd say, go for a 2 speed pump, but none of the 2-speeds seem to be able to overcome the normal runtime 30 feat head...
So I'm a bit stuck here...
I also read a lot about overdimensioning sand filters and salt water generators, so am not sure what would be the best size now.
I am thinking a 3.69 sqft. sand filter, which would allow up to 74GPM according to the 101hydraulics, and a hayward aquarite 9-cell?
We have plumbed the sand filter to backwash using springwater (we have free and abundant water), to avoid dumping treated water.
SPA:
Further on, I have plumbed the spa drain with a syphon, to prevent it from draining into the pool when the pumps are out. Communicating barrels and all...
Perhaps there is a better solution for this? On the return side, I can place a no-return valve.
The spa also has an extra pump for spa jets. Which can be turned on from within the spa. This powers a loop pipe of 2" piping, which sucks air through an air pipe of 1.5" that has a syphon in it above pool level.
It has 2 three-way valves to turn run through the collector or heater. We are not sure yet which would work best. Perhaps the solar collector will be enough in our climate, but we'll have to see what happens there.
INFINITY EDGE:
The infinity edge return has a separate pump, as it seems this is the only way to solve this. The buffer tank is a concrete tank in the pool room, as we don't like to build a big and wide collector next to the pool.
The pool overflows into a small ditch with a stainless steel mesh that holds out large debris. It flows into two 2" pipes that gravity feed the 1.500 gallon buffer tank.
The buffer tank has an overflow for storm and rainwater. It is a non-pressurized tank, and has an air intake to prevent vacuum. It uses a float valve to fill up the pool water in case of spill or evaporation.
I was thinking of running this pump with an IR sensor, to only turn on when there are people around and in the pool. But maybe there are better solutions for this as well. I've read about sensors to control pool level. But again, am skeptic, as I try to stay the easy fix, low tech course...
So, to summarize:
We try to design our pool with 'simple' technology.
- I'm not sure about which pump to pick, I believe I have all the info, but can't seem to find a low-tech, energy efficient pump that does what I need.
- I am not sure about over or under sizing the sand filter and SWG, and as I cant pinpoint the pump, I can't determine the exact flow.
- I am not sure if the plumbing solutions I have chosen for the spa will work well.
I hope someone can give us some input on what would work best, and that this may help others with a similar setup.
POOL SETUP:
![tristar-specs2.gif](http://images.inyopools.com/cloud/descriptionimages/tristar-specs2.gif)
SPA:
INFINITY EDGE:
So, to summarize:
