I don't think super chlorination would cause foamy bubbles but algaecide certainly will.
You should be able to find an ammonia test kit at Walmart in the pet department. Maybe around $15 to $20 or so.iam4iam said:Can anyone recommend a test for ammonia so I can check that possibility?
iam4iam said:I am not frustrated by not knowing how far I am from shock level. I am frustrated by not being close after 2 times as much chlorine as it should have taken to get me there! While a test kit might tell me exactly when I get to shock level, unless a test kit will tell me exactly why I cannot get there, it will not end my frustration.
I didn't think I had much of a hill to begin with, since I could see 3-5 ft deep as soon as we took the cover off. The fact that not much has changed is the real reason I'm so frustrated.Eventually you crest the hill and it's a pretty good feeling.
samiguy said:... I ... tried to hold onto my old ideas until I got tired of wasting money on my "rational thought process".
Yep, Swampwoman is correct.As for backwashing, I've only needed to after vacuuming. As far as when it's needed, I think I read on this site to wait until 10 psi over "normal" pressure. I do admit, though, that it makes more sense use a % as a guide. My "clear" pressure is 13-14 psi. Other thoughts out there on using % change in psi as a guide for backwashing?
