One of our customers got back from up north and I tested his water. He had a Free Chlorine level of 25 with 0 CYA. I understand this to be extremely harsh and we had the tech that was responsible for maintaining his pool immediately correct the CYA. This is a salt pool mind you. He came back a few days later and told us his heater was completely corroded out and his pump was also victim to high levels of corrosion. The pool levels were maintained properly for the months we were taking care of it until the last month when the CYA was neglected.
He is blaming us for the corrosion and saying it was due to poor water chemistry. Thing is, the corrosion is from the outside not the inside. Also, the part of the heater that was corroded doesn't even have pool water contacting it. The exchanger was fine. Is there any merit to his claims? Is it possible that a month or less with elevated FC and 0 CYA caused this problem? Can that cause corrosion that rapidly?
Hoping chemgeek can weigh in on this one. Wouldn't the corrosion be coming from the inside out if it was from water chemistry? Any input would be greatly appreciated.
