Hey all, I'm starting to get a handle on things but I'm still learning...I think I have a fairly complicated system (brand new) and I want to get my levels correct. I should say that my water is crystal clear, free of metals, and has low hardness (comes from a well) and is always at 7.5 pH. Here are some specifics on my system.
So now the questions:
- Variable speed pump that runs at a low RPM 24/7
- Sand filter
- SWG for converting salt to Chlorine
- UV/Ozone system as a secondary sanitation system
- CO2 system to balance PH
- ORP system that regulates everything.
- Pool usage - mainly just 2 people (me and my wife), daily but for an hour or so.
- Pool size 38,000 gallons.
- Pool location 100% full sunshine in the Shenandoah Valley of Virginia.
- What CYA level should I have -- From my readings here SWG pools should have a higher CYA than a non salt-water using direct chlorine - but I think I also saw somewhere that ORP's don't work well at higher CYA's so what should I be at?
- TA - what should it be so that the PH doesn't fluctuate too much
- CH - does this matter at all? My pool store says I need to make my water harder (because all chemicals affect each other) but while I think hard water can be a problem, soft water shouldn't be (after all people with hard drinking water add systems to soften them but I've never heard of anyone adding something to harden their drinking water.
- One last question, my pool company says I should shock once a week - but that makes no sense to me. My system is trying to keep everything nicely balanced and should have plenty of disinfecting power to keep everything clean...and as I said it's crystal clear and seems very comfortable (no burning in eyes or skin) so dumping a ton of chlorine into a system that is trying to keep chlorine regulated seems like it would throw off everything, yes?
