Converting to SWG - which test(s) do I need to add to my kit?
Stephs2125
86
SE Michigan
CircuPool RJ-60 Plus
Hi there, so we are still a couple of months away from opening (it's still dang cold here in MI), but I purchased an SWG at the end of last year that will be installed this spring along with my new filter, pump & heater!! Super excited for all the brand new equipment :D So here is my question (s). I currently have the TF-100. What additional tests do I need to order for measuring/maintaining my salt levels? Also, I saw I got an email to get a set of replacement tests for the TF-100 with a nice discount. Is replacing every year recommended? Do they expire? Or is it just to replenish if you are low?
The scheduled opening is May 13!! Close...but still so far :cry:
I recommend getting the drop salt test (K-1766), but the strips are ok. That's really all you need to add to your kit.
As for the refills, while it's not a bad idea to get a full refill kit, I wouldn't replace everything. I would make sure that all the reagents get replaced every two years. So if you haven't used a reagent in two years, just go ahead and replace it.
If a reagent changes consistency or color then definitely replace it.
Reactions: Stephs2125
Thanks!!
