I have been a member since last year. New to owning a pool. This forum with the app helped loads getting my chemistry back on track from the previous owner. I highly regard this community and all of its members. That said, here is my current setup:
38k gallon gunite pool built in approximately 1995
Pentair 1hp single speed pump
New Hayward Tristar VS950 (Not installed yet/got a deal)
Pentair Tagelus TA-60D sand filter
Polaris booster pump for robot
Raypak 406A Heater (Brand New/ installed 2022)
3" puck style chlorine tab feeder
Pentair CVA actuators x4 (Not installed yet/got a deal)
2 skimmers, 1 floor drain, 1 booster port (on 1x3/4" feed), 3 feed ports (on 2x2" feeds)
With the new season coming, I really want to get the pool converted over to salt and add some automation. Initially I was headed towards chlorine/acid dosing pumps with tanks and ORP/PH Sensors. Started collecting components, and just decided to go SW. I plan on replumbing with some new valves and using the actuators for automation along with installing the new variable speed pump.
So, the question is this; I know I have some mixed components; but would like opinions on which brand system and size to go with for SWG. I am not worried within reason about budget but there are products which will give me great results and longevity. Also, how do I clean up this mess and make it look neat and tidy? I am considering pouring a slab to set all the components on. There is a 4 foot gap between my pool house and the components on the back side.
Any other recommendations for updating the system and for automation would be great.
Thanks you TFP.
Thanks you TFP.
