I have a gunite pool and a spa. The spa is about 3' above and 10' away from the pool, connected with a spillover and a decorative stream feature. The feature leaks due to 25 seasons of movement (cracks/gaps at pool connection, spa connection, decorative catch basin) so I want to replace it with underground pipes.
Q1) What is this new design called? It'll need some leveling/overflow outlets that connect to pipes that return to the pool.
Q2) What sort of faceplate or connector can be used as an overflow to pipes?
Q3) Do I need a skimmer? Can I get away without one?
While it was leaking, I bypassed the feature with 2 2" PVC pipes and a catch bucket. I'd like the equivalent of that design (though built onto the wall of the spa and not visible).
Any advice? I saw some wide mouth skimmers for vinyl pools that might work if I used a skimmer. Would that work for a gunite pool?
This post: SPA Overflowing in Bypass mode. has a similar design to what I want, but I don't know how the plumbing works from their photo.
Thanks for the help! --ed
