- May 22, 2016
- 39
- Plaster
- CircuPool RJ-45 Plus
Hello,
I'm strongly considering the switch this summer from LC to SWG, but I am concerned about galvanic corrosion which I have read about. The pool is plaster and built in the 1975. I understand that if the metal components were not bonded, then the metal (rebar, pump, etc.) may corrode over time. Should I be concerned about this and how can I know if it is bonded? Also, should I expect the steel fasteners/joist hangers on my composite deck around the pool to corrode quicker with SWG water?
Thanks for your time and expertise.
16,000 gal quartz plaster finish, 1.25 HP single speed pump, Hayward C1200 filter. Water balanced using TFP method/pool math app for two years.
