I am going to be changing my pump this week and I've decided to redo the above ground plumbing. Right now on the suction side I have a 1.5" line for the skimmer, a 1.5" line for the dedicated vacuum port, and a 2" line for the main drain. Currently these all connect into one single 1.5" line going into the pump.
On the return side, above ground, I only have one 1.5" return. There are three return jets around the pool though. I don't know how far into the run back to the pool it splits off.
I pretty much keep the main drain shut and keep the skimmer and vacuum port open. I was going to redo the suction side plumbing to be all 2" above ground going straight into my new pump. It got me thinking if it would be a good idea to turn the main drain into a return. That way I would have 2x 1.5" suction lines and 1x 1.5" and 1x 2" return lines. It could easily be undone since it's all above ground.
It sounds a little crazy even to me. Opinions?
