- May 28, 2020
- 1,239
- Vinyl
- CircuPool RJ-45 Plus
Hi All,
Before starting up my AGP this season I want to get rid of the flexible tubing and hard plumb everything.
I am planning to use 2" Sch 40 PVC with the equipment in my signature.
My question is regarding the flow rating of my filter. The manual says that it has a "design flow rate" of 50gpm.
Does this mean that the pressure drop of this filter will yield 50gpm at some semi-standard nominal head output from a typical pump?
Or does it mean that I have to be careful to design my plumbing to ensure that flow stays below 50gpm so that I don't cause damage to the filter internals?
If the latter is true, then maybe I'd be better off with 1.5" piping instead of 2", and may still need an additional flow restriction to limit the flowrate on the high setting.
95% of the time my pump will run at low speed, which makes this question irrelevant, but when I vacuum or need some extra skimming, I will need the high setting.
Thanks in advance for the advice.
