Conventional Wisdom re SWCG plumbing placement
At 20 GPM and 2 lbs production per day, the FC is increased by 8.3 ppm from inlet to outlet.
If you have 8 ppm before the cell, then you have 16.3 ppm after the cell.
Also, not all of that is combined with CYA because that takes time.
It's a good point about CYA: The water leaving SWCG is probably much more aggressive (oxidizing) than what the target FC and the CYA level would suggest.
I’m not completely convinced that a heater substantially downflow from the SWCG “feels” the total brunt of that 16.3ppm, CYA or not. But ok, you’ve all convinced me not to put the cart before the horse, er, the SWCG before the heater.
I didn't review all the posts (new and old), but it seems if the second daylight photo shows your heat pump (photo also has the post with the small electrical box) - then your solution is to slightly expose the outlet pipe coming from the heater, and plumb the new SWCG in a vertical loop configuration. Outlet of the heat pump goes up a few feet, loops over, and on the downward leg install the flow switch and the SWCG cell, where it then mates up at ground (or a few inches into the ground) with the existing outflow pipe. Circupool for one actually markets a vertical install kit - although it is just the same pvc pipe fittings you can buy locally, cheaper, anyway. I did that last year with my above ground setup, due to space considerations. In addition, there would have to be a serious back siphon event for anything to get to the heater.
Worst case for the install is that you may elect to have a number of 90's installed to get the vertical loop to clear the other obstructions, so it may look a bit Rube Goldberg-y.
Reactions: TishTash
… lightly expose the outlet pipe coming from the heater, and plumb the new SWCG in a vertical loop configuration: Outlet of the heat pump goes up a few feet [and] loops over;… on the downward leg install the flow switch and the SWCG cell, where it then mates up at ground (or a few inches into the ground) with the existing outflow pipe.…
Thank you for the several tips. This reminds me of a question I have about one of the instruction manuals earlier in this thread: Why the connection (circled) in this picture?
Loop Plumbing Diagram.
The IntelliChlor® SCG is designed to operate with water flow rates from 25 +/- 5 gallons per minute (gpm) up to
105 gpm.
Refer to the pipe manufacturer specifications for recommended maximum flow rate.
For flow rates over 80 gpm you must use a bypass loop (as shown below) for best chlorine production.
Installations with flow rates over 80 gpm include those that have in-floor cleaning systems or booster pumps.
These systems MUST use a bypass loop with the IntelliChlor SCG with a flow control valve that assures that the flow through the
IntelliChlor SCG is maintained within its designed operating water flow rates.
