- Jul 21, 2023
- 4
- Plaster
- Pentair Intellichlor IC-40
I have read the helpful posts on configuring UltraTemp and Intellicenter. I even went out, purchased, and installed a Solar Sensor just to get the two to talk. I now have heartbeat and am able to have Intellicenter (F/W 2.017) turn on my UltraTemp 140HC (S/W 473788.D.1) in Cooling Mode as a scheduled item. However, the target set point displayed by the Intellicenter in cooling mode is the Heat Set Point (lower than cooling set point)! This causes the UltraTemp to cool the pool well below desired temp and trigger a post cool down heat up. I have confirmed that the UltraTeamp is attempting to cool the pool down to the heat set point. Does Pentair really think this is normal? Why would someone want to cool a pool to the point that it is heating it. I have set the Temperature Differential to 3 which means Intellicenter forces a minimum of three degrees between Heat and Cool Set Point.
Heating seems to work as expected. I set the SPA and it turns on 1 degree below the set point and turns off 1 degree above the set point with the Intellicenter managing the temperature. It was 114 degrees degree today and I have no need to heat the pool, but I believe the results would be the same for Pool mode operation.
Am I missing something?
