Hi all,
I just read an 'old thread' that was relating to what I needed, but it did not 'finish' the thread and so I still have a question. I currently have low voltage overhead LED lighting system for our pool lanai area. We also have a low voltage pool light that is controlled by a wall switch. We had an electrician that installed the overhead LED lights and he put a switch INSIDE the Pentair box that was a wifi switch (see picture below) Our thought was we wanted to be able to "control" the time the switch was on since we also rent out this vacation home. Well, the Wifi switch has stopped working (I think it is a 'range issue' since the box is outside the house).
So, I want to wire the switch directly into the Pentair and remove the 'wall switch' for the pool light and control both from my remaining (1) Pentair relay. I am including a current picture below. I thought I was just going to remove the wires from the switch (the electrician installed inside the box) and put the wires on the relay, but I'm not sure if they are already stepped down to low voltage or not.
My question is, can low voltage wires be controlled by the Pentair relay directly? or do they need to be the high voltage putting OUT to the low voltage transformers??? (and can I put both on one relay either way?)
Thanks...George
Thanks...George
