- Aug 22, 2017
- 2,627
- Plaster
- Hayward Aqua Rite (T-15)
So I just received a Pentair Intellivalve that I am looking to hookup to my DIY controller. I am not sure how the wiring on it works. There is a black, red, and white wire in that order (there is also a green and yellow reserved for future use, RS-485 control). With most actuators it seems like the center wire is the common wire and you apply power to either side to move it in either direction. That does not appear to be the case here.
The black wire appear to be common (at one end of the three). If I apply power to either the red or white, the Intellivalve turns on and I can program it but it does not move. The behavior seems the same if I apply power to either red or white.
So my question is what do I do to make this thing turn? I did not try applying power to red and white together since I dont want to accidentally blow up my brand new $150 valve actuator.
