Moderator comment: This post was separated out from this thread:
Sorry to post in an old thread, but wanted to clarify the install...
Physical Install
Using a Jandy 2711 3-pin connector (outside pins used), connect to the open 'SOLAR' port.
Wire the leads from the 'SOLAR' port to a 24V DC Relay (may need to purchases). Incoming power from breaker goes to the LINE on the relay and LOAD is wired to your light transformer, along with common and ground off their respective blocks.
Programming
This is where I am a bit iffy. I think you are supposed to go to Menu > System Setup > Assign JVAs. Click the 'Solar' button and click 'Extra Aux' from the list and click 'Select'. This is what my screen looks like below.
Couple questions at this point... I assume Extra Aux is like a virtual auxiliary?
Also, why would it let me choose Aux1, Aux2 or Aux3 if they are already in use for things like spa blowers and pool lights?
After that I would want to go back to System Setup > Label Aux. Rename 'Extra Aux' to read something like "Low Volt".
From there you could setup "Low Volt" in Dusk Setup and be on your way?
Assuming you could also do the same with the Cleaner button?
Controlling Low Voltage Landscape lights
Hmmm... I have an unused relay in my iAqualink and have my landscape transformer plugged into a receptacle that goes back to the iAqualink load center on its own dedicated 120 volt breaker. Is there a way to link that breaker to the extra relay and control those lights with my iAqualink? That...
www.troublefreepool.com
Physical Install
Programming
