Contract Signed
Aug 1, 2017
14
Lansing/MI
I have just signed a contract for my in ground 16X32 pool with 8X6 vinyl over steel tanning shelf. The pool is 4 feet deep the whole distance of the pool. About 16,000 gallons.
Contractor said I should be swimming by 9-15-17.
Here is the equipment he is using
AquaRite w/TurboCell Salt Chlorinator
24 Inch Hayward Sand Filter
Super Pump 1.0 Hp single speed Hayward pump
H200 Hayward heater 200,000 BTU
Hayward Large 12V Switched Color pool light
Any recommendations on this equipment ?
Money is not an issue too a point if upgrading would make the pool better.
Thank you.
S,
When you have a SWCG, you often have to run the pump for a long time to generate the amount of chlorine needed to sanitize your pool. To do this with a single speed pump can be costly.
I would go with a 2-speed pump or a variable speed pump, which will reduce your electrical bill.
Thanks for posing,
