Hi all,
I had a pool built in 2017, and have had a continuing issue with limestone coping cracking in one particular area. The pool was finished in July 2017. I first noticed a crack in the vertical side of the concrete decking in May 2018, followed shortly by a crack in the coping above the same area.
I advised the builder, who said it was normal settling and advised to wait until after summer to allow for any additional settling before repair. The first repair was done in June 2019.
There was further broken coping in the same area in September 2019 which was also repaired.
I discovered additional coping cracks and concrete cracks, along with cracked tile in May 2020
One of the owners of the company came out to inspect, agreed this was not acceptable, and committed to repair. Coping section was replaced. A corner of the concrete deck was cut out and filled with new concrete. Everything was painted and the mastic was entirely replaced after these were taken, and everything looked fine. The repair was not able to be completed until October 2020.
In July 2021, cracks again began appearing both in the coping and the side of the deck where the repair had been done.
When I talked to pool builder, their position is now that the cracking is caused by ground movement, is cosmetic, and as long as the shell doesn't leak it is not covered by warranty. They sent me a copy of the contract/warranty. They could possibly repair at our cost sometime in the future. Timing unknown due to how crazy the pool construction business has been for the last couple of years. I am not at all happy with the builder at this point and have let them know.
I would like to get this repaired, but want the repair to last. There seems to be some sort of underlying problem, as this keeps happening in the same spot. I think there is something that is not allowing the deck and pool to move independently when there is contraction/expansion due to heating and cooling of the deck. I am open to any other ideas. I have a few pictures taken during construction of that area if that would be helpful. Thankfully the use of the pool is unaffected, but it is very irritating to have such a large investment not looking as good as it should.
