24' 52" or 54" wall Above ground about 9 years old now. last fall the problem started where I would vacuum and within hours the residue would show up again. it starts showing up on the far side of the pool opposite of the return/intake. its a very light brown almost white, believe to be dead algae. I thought it was sand, it is not. I put socks on the skimmer basket, they catch a ton of stuff and get clogged within a couple days. Lots of sun, no trees. Alkalinity is 120, pH is 7.5-7.8 on the test block, cya is 45, FC is 5-7 consistent (i use liquid chlorine). I did SLAM for 3 days of 20FC. is this a filter issue? This morning when i shut the pump off to remove the skimmer sock, a lot of white cloudy water in the skimmer due to the disturbance. when i turned pump back on, a lot of cloudiness came out of the return jet. please advise.
