Good Morning. I fought this some last year but it has gotten worse this year. Below is a set of my current numbers. I have kept the numbers below "about" the same, typically the only thing that has fluctuated since opening and balancing is the FC and CC (and CYA from all of the vacuuming to waste, so I have replaced as needed). Losing on average of 3-5 ppm per day and 1.5-3 at night. All other numbers has stayed the same since opening in May (I have let it dip below 10 ppm a few times to ensure I got an accurate PH reading). I brush everyday, vacuum to waste almost daily and still right back in the same spots, sometimes worse and sometimes in other spots. Between the bleach and the water replacement it's getting expensive quick. When the spots are swept they poof up. Otherwise the water is clear and has not been cloudy, even after sweeping the spots. I have inserted some photos below. One shows the problem and the others mark the areas in the pool where the spots keep coming back. The middle arrow indicates that there are various spots that show up in the crease where the floor meets the wall. The problem picture is directly on the lip of the transition from the shallow to deep end. The arrow to right is to indicate the wall and the drain area. Can anyone shed some light on what I am dealing with?
FC-16
CC-2.5
PH-7.6
TA-110
CYA-30
CH-250
FC-16
CC-2.5
PH-7.6
TA-110
CYA-30
CH-250
