Guys -
I have a pool that is currently using CALHYPO 73%, 12.5% liquid bleach, no trichlor or stabilized chlorine due to the CYA issues associated with it, CYA is kept at around 35 PPM, CA around 280 (pebble pool), TA around 90, PH around 7.5 to 7.2. You can see my test logs when you click on my profile. This has been a battle keeping chlorine in the pool this year here in SE TX. The pool is 91F and I know that the CYA being kept lower is of course causing my chlorine levels to drop daily and weekly. I want to keep the CA and CYA lower and not fight chlorine lock with stabilized chlorine tabs so, I do not use it and as a result I am spending too much of my time maintaining this pool. I have order the sense and dispense system from Hayward directly, as I am also a consultant and pool builder here in TX. I waited for the update to the OmniLogic software to come out that supports the new liquid chlorine injection system vs. the older sense and dispense that only did SWG and acid injection. I have started to second guess this logic, as I this whole thing has become a big pain in the rear end. I know the results of using bleach in the liquid form will raise salt levels so why not just use a SWG and lower my maintenance touch time on this pool? I also know that I am about to reach the limit on my pool's ability to use CALHYPO due to calcium limits approaching my limits. I will not use stabilizes chlorine due to the issues with CYA and chlorine lock... I do not want to drain the pool when we finally get above about 60 PPM of CYA so, I have chosen to just not use the stabilized chlorine. The pool has OK and TX flagstone in beach entries and sun shelves so I am a little hesitant to move to salt and use the SWG but I am adding salt with each gallon of 12.5% liquid chlorine that I pour in... Any thoughts?
Pool data:
Consultant on custom home building, custom, higher end pools, and automation.
Pool - 40,000 gallons, Infiniti Edge, SPA, Pebble Sheen, Blue Surf
Equipment: OmniLogic with all expansion modules, direct network connection, 5 VS950(s), HSP30060 Booster Pump, Polaris Qauttro Sport, 8 Hayward actuators, Hayward C7030 Cartridge Filter, LACUN150 Colorlogic LED lights (x16), Hayward WFL100 Laminar(s) with lights x4, Hayward WFB100 Bubbler with LED x2, Pentair ETI-400 Titanium heat exchanger condensing heater, 2 HP blower, Sense and Dispense for liquid chlorine and acid on order, to be installed... 3 pumps (1) pool pump, 1 catch basin pump, 1 booster pump on backup generator power...I think this is about it...
Pool data:
