This is the procedure sent by Aqualink. I tried it tonight and it worked perfectly.
For an Eero, the process is to enable guest access, then connect your antenna to the guest network. At this time, there is not another way to connect as Eero otherwise only supports WPA2 and your antenna requires WPA.
To connect your antenna using the hotspot method you’ll want to;
- Take the cover off of the antenna with a Phillips head screwdriver (+)
- Toggle the black toggle in the center over to wired, then back to WiFi
- Go to your WiFi settings on your phone, there should be a network called 'iAqualink-xxx' connect to this
- A login page should appear shortly after connecting, this will pull up all the WiFi networks the antenna sees to connect with
- Select your Guest WiFi network, When inputting your password, be careful, the keyboard auto-caps the first character, make sure to double-check your password
- The antenna will now try to connect, you can verify if it's connected by checking the status lights. There are 3 lights on the outer left side of the antenna (Red, Yellow, Green) If all 3 are lit, the antenna is connected.
