Connecting 2-21/2 inch pool pump to 11/2inch plumbing
Put the union on the pump connection then use a reducer fitting to go back down to 1 1/2” pipe.
You could put everything as 2” pipe but I assume you must have 1 1/2” pipe coming up from the ground to feed the pump? Show a photo of your equipment pad.
