Hello all! It’s been a few weeks and it’s been going pretty good for the most part. I’ve had a few issues that I think I’ve taken care of as much as I can by searching and reading here without asking any questions.
I discovered a few things at the end of July. When buying the pool the frog System was part of the package. I discovered exactly what that was through you guys and didn’t want to have it installed. However I had an appointment the day the installer came and my dad was here and It was added to the plumbing of the pool. However we thought since we didn’t plan to use it and didn’t put any of the stuff that came with it together that it was just something else attached and I was going to remove it whenever. WRONG! The mineral reservoir was preinstalled. So we were push copper and silver into the pool until I discovered this on July 20. I removed it. Got the PH, TA, & cloudy water taken care of and it’s been beautiful since!
I took the water to leslies on July 21 to get the water ran to see what the metal test read since I don’t have anything to read that. My dad brought it to be tested again on Tuesday because my little boys hair is greenish!
The pool looks great even with the downpours the past few weeks. But I’m feeling a little questionable about the water because of his hair and the amounts of rain we’ve faced!
I also spilled my last CYA test Tuesday while testing so unfortunately I am using the pool store’s results because of the amount of rain and backwashes I’ve need to do since it Was a steady 50. So don’t get on me too bad!
Test results below
Leslies July Metal numbers
Iron- .2
Copper - .8
Phosphates- 622
Leslies Results from This week
Iron- .0
Copper - .3
Phosphates- 976
CYA- 35
TC- 1.18
My results this morning after yesterday’s storms. I Brushed and vacuumed to waste so I could bring my water level back down again.
FC 0. Added 43oz lc to reach 6
PH 7.2 Added Borax to reach 7.5
TA 70
Also added around 11 oz of stabilizer to increase CYA to 50ish
Have the outlet aerating and the kids will be in the pool so I didn’t add anything to increase TA will double check tomorrow and add recommended 13oz of baking soda if it needs it
With all the rain I know my FC levels haven’t been correct daily because of the rain. I did put a floater in the pool and got the pool essentials pucks from Walmart. Knowing all this I’m just nervous that I need to worry about the high TC, Copper, & phosphates.
Id like to get the green hair to stop is that the copper?
Please help!
Sorry for the book! I just wanted to be as descriptive as possible!
Test results below
Iron- .2
Copper - .8
Phosphates- 622
Iron- .0
Copper - .3
Phosphates- 976
CYA- 35
TC- 1.18
TA 70
Please help!
