New pool owner since Nov 1 and I've been using bleach since (except for the first 2 weeks when the pool company added pucks to our chlorinator). My water chemistry has been perfect for all these months based on Pool Math and thanks to this site members for their insight. My CYA has been 30-35 consistently. I have an automatic cover which during the winter and early spring has been covered at least 95% of the time. I add about 8-16oz of bleach about every two-three days, sometimes longer depending on the temps. Although Pool Math recommends having FC at 4 based on my pool gallons, I always add a bit more bleach and like to hover around FC at 5+. Nervous newbie I guess.
My question is, we are coming to a hot Texas summer and I'm just thinking I'll probably have the cover off during the afternoon/evening more often, should I be raising my CYA? When looking at Pool Math, raising CYA to 40 and even 50, which still stays in the ideal range, I will need to add more bleach. Also, based on reading other posts, adding bleach won't be a two or three-day task in the summer. So why increase my CYA if I will need to add additional costs of adding more bleach? If I need to add bleach every day, I might as well add just 8oz. and nothing more, based on my CYA at 30. Is my thinking correct here? I'm only questioning this because I've read from numerous posts to have more CYA during the summer so as to maintain FC longer. Is that correct?
Also, if adding CYA to 40 or 50 is the way to go, I have a few pucks hanging around from the pool company. Based on Pool Math, adding one 8oz puck will give me FC 9.1 and CYA of 5.5. But I assume this is only if I set the chlorinator to the highest level, 5, correct? If I set it at 1, I assume it will provide a gradual increase in FC and CYA. To what degree setting is confusing but can I assume its just a trial and error? Thanks,
